lowered cars and deep transpans
tony
Not sure if that helps...
There are also "reinforced" pans available that have a big steel plate on the bottom for protection.
24210915* - This deep transmission pan holds approximately two extra quarts of fluid and can be used on any 4L60 or 4L60E transmission.
24208576 - Oil Filter Kit (Filter, Pan Gasket, O-Ring).
off my SS because I kept scraping / bumping the drain plug
on speedbumps. This is the finned aluminum one that has the
"stepped" profile to the bottom of it. I bet at 2" drop you
would be busting fins or cracking the pan, not just tagging
the drain plug.
would a stock height camaro with 70K suspension have enough clearance and not bounce back into the speed bump driving normally (ie 5mph bump)
