need help with trans cooler fitting adapter....
Old Sep 8, 2012 | 11:28 PM
JeRM82's Avatar
Default need help with trans cooler fitting adapter....
So I have been all over the place looking for this adapter fitting for my trans cooler set-up....this adapter is the SHAPE that I need but isn't the right size.....
Does anyone know of or can anyone find a part number for a fitting that is the sizes I labeled in the picture? I'm wondering if this is an odd size that I should just convert to all AN fittings if I can't find it......what a pain in the A$$.....2 fittings and I can fire this thing....HA HA!
Old Sep 9, 2012 | 06:50 AM
therabidweasel's Avatar
Pretty sure, but not positive the us what you need:
http://m.summitracing.com/parts/bci-72001
Old Sep 9, 2012 | 07:00 AM
mbaker3's Avatar
On my F-body (2002 camaro) the tranny cooling lines are 5/16 inverted flare fittings. The fitting that actually screws into the tranny cooling side of the radiator is a 5/8-18 inverted flare fitting. I just converted my lines to 6-AN braided lines and it fit.
Old Sep 9, 2012 | 10:01 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
On my 98Z,the metal part of the transmission fluid cooler lines are 5/16" OD steel tubing. The fittimgs going into the radiator are 5/16 inverted flare that have a 1/2-20 thread connection into the radiator.
