What type of oil does a 4l60e use?
Old Sep 25, 2012 | 09:57 AM
jerrito98ss's Avatar
Default What type of oil does a 4l60e use?
What type of oil does it use???
Old Sep 25, 2012 | 11:35 AM
mrvedit's Avatar
Moderator
For the past 10 years or so, GM has recommended Dexron VI, a full synthetic.
Many people use the cheaper Dexron III; I have not seen any strong argument for Dexron VI. Nonetheless, my local trans shop sells me Dexron VI at $50 a case of 12 and that is what I use.
BTW - There is an interesting current thread on using Hydraulic oil. Seems that ATF is hydraulic oil with some additives and red dye.
Old Sep 25, 2012 | 12:47 PM
DietCoke's Avatar
Plain ol dex 3 for me
Old Sep 25, 2012 | 01:44 PM
LS-ONE_DAY's Avatar
I was running Dex VI (I think, it was whatever was in the car when I bought it and since it has under 30k miles it's on the stock fluid probably)
When I put in my trans cooler in I obviously lost a little fluid. I ended up putting a splash of Dex M in it to make up for the fluid loss. I had a shop install my converter, no idea what fluid they used.
Dex III/M should be fine, Dex VI for best results.
Old Sep 25, 2012 | 02:37 PM
mjs1012's Avatar
Just plain old dex 3 works fine.
Old Sep 25, 2012 | 08:40 PM
TransAmWS.6's Avatar
Dexron III should work fine, I've had it in mines for the past 8k miles or so
