chaging tranny filter, cannot get seal out
Old Apr 8, 2004 | 10:58 PM
Caveman's Avatar
10 & 11 Second Club
Angry chaging tranny filter, cannot get seal out
I am changing my tranny filter and I cannot get the seal out of the tranny. It,s a 4L60E I,ve already reused the seal once and wanted to change it this time. Seems like it is a pressed fit I have used every tool I could think of and can,t get it out any ideas would be helpful.
Old Apr 8, 2004 | 11:10 PM
yukz's Avatar
I had the same problem I tried everything but faild, the seal looked as if it was melted in there so I just gave up and left it in there and 2k later my tranny started to slip but I am not sure if the seal caused it, so try every to get it out.
Old Apr 9, 2004 | 12:55 AM
98silverformula's Avatar
Talking
yo i just did my a4 and the seal was a bitch to get out had to take a screw driver and put it to the seal and then hit it with a hammer to cut the seal in half then it came right out
if you cant get it bye your self i will come over and do it for you for food
Old Apr 9, 2004 | 07:27 AM
Hawkn01's Avatar
I have the same seal and have changed the filter twice and no problems. I always put alittle grease on the neck of the filter to help it slide in without damaging the seal.
Old Apr 9, 2004 | 07:40 AM
jfm's Avatar
jfm
If you have not damaged it leave it in and use Hawks advice.That thing is a PITA to get off and probably will need to be split,be careful not to damage anything.
