4l60e shattered pump impeller
thanks
Joe
BTW, I assume by "pump impeller" your mean what GM calls the "pump rotor".
First, I would check if either "pump ring" broke - early year ones were susceptible to break and ruin the entire pump. I suspect this is not the case.
Second, I suspect you are right about the converter being the problem. I suspect the converter is wobbling; the pump has clearance for a bit of wobble, but not a lot. If either the mounting pads on the converter or the holes in the flexplate are out of position, it would wobble.
While a bit involved, you might be able to check this with the trans removed by mounting the converter to the flexplate and either starting the engine or at least spinning it with the starter to visually see if the converter is "true". (I have never needed to try this, so I admit I am guessing here.)
Perhaps someone else has better ideas...
Perhaps one of the converter experts will chime in soon...
