How long to warm up?
Old Oct 13, 2012 | 06:47 PM
CayenneRedV6's Avatar
Default How long to warm up?
How long does it usually take auto trannies to warm up? I just installed a temp gauge and took my car for a drive. I drove around for 15 minutes or so romping on it a little and it just barely got to 150* and took the whole time to get to that. Not sure if I broke the sending unit or it's normal to take that long to warm up. Thanks.
Old Oct 13, 2012 | 06:58 PM
ULTIMATEORANGESS's Avatar
from what i remember trans temp is about 30 degrees below eng. temp.
15 min. should be long enough to get an accurate reading.
Old Oct 13, 2012 | 10:23 PM
Guess I F'ed up the sending unit then. Thanks.
Old Oct 14, 2012 | 07:35 AM
ctjohns's Avatar
Do you have a cooler catching airflow? May run cooler than you think
Old Oct 15, 2012 | 06:36 AM
Yeah I have the cooler mounted in front of the radiator with no A/C condensor. The sending unit is definitely messed up though 'cause it's not working at all now. I ordered a new one and I'll have to be extra careful while installing.
