Nagging Question
On the street,1st and 2nd with 4.56s' were wicked,mpg was good as the computor handled it well,21.5 mpg at freeway legal speeds,2500rpm @ 60mph 3000rpm @ 72mph.
Even took 5 trips to Florida from Ohio with the 4.56s'. Currently got the OEM 3.23 rearend in it. Gonna put the 4.56 rearend back in after I change it out to 3.73s or 4.10s'.
-4.56s' for a pure street car and fun
-4.10s' in a stock(or close to stock) car for street and strip
-3.73s' is the typical recommended ratio mod
With 3.23s' on long trips I got 24.5mpg,with 4.56s' got 21.5mpg. So 3.73s' should be 22.5mpg and 4.10s' should be 23.5mpg.
Thinking I may start out with 3.23 and if I want more ill go with a 3.73
My new issue/recent discovery. I was dicking around at a cruze night and tried to put the car in first... yeah that was a fight. Now it slips out of the selection and into second
Do not confuse this with trans slip. I'm talking about the selector. From 2-1 I have to hold it in place. Is this normal for these cars?
From a stop in 3rd or 4th,the forward sprag is engaged,from a stop in 1st or 2nd,the overrunning clutches are engaged.Too much manual 1st or 2nd from a stop will prematurely burn up the overrunning clutch.
