B&M trick shift fluid
Old Apr 10, 2004 | 11:46 PM
heyitsTaJay's Avatar
Default B&M trick shift fluid
i was told to put this in if my fluid was low. I started to pour it in and its green or some dark color? so i stopped. My stock fluid is red. is something wrong here or is everything ok?
TIA
J
Old Apr 10, 2004 | 11:56 PM
JoSeY's Avatar
It's ok...trick shift is all I ever used in my tranny
Old Apr 11, 2004 | 08:56 AM
jimmyblue's Avatar
Moderator
It all depends on whether your torque converter clutch
likes it for the material used. My TCI w/ carbon clutch
sure did not. I think organic clutches will tolerate it more
than ceramics. You really ought to get the opinion from
your converter manufacturer as there are too many
different TCC materials systems out there to generalize.
Old Apr 11, 2004 | 10:22 AM
thats a really good idea...
J
