3600 converter with 10 bolt
Old Oct 23, 2012 | 05:56 PM
texas99Z28's Avatar
Default 3600 converter with 10 bolt
Tried to search, had no luck. At 360 rwhp and stock 10 bolt, would it be a horrible idea to add a converter? Keeping in mind that adding the converter will mean DR's to hook up. Car will hardly ever see the track. Thanks for any opinions. Please only replies from people who have owned a car with this setup!
Old Oct 23, 2012 | 06:20 PM
bstuby's Avatar
You will be fine. Just put a trans cooler in and call it a day.
Old Oct 23, 2012 | 06:24 PM
swoop's Avatar
I have a 4k with a 10 bolt, 400rwhp & DR's. So far so good, with that said I am looking at upgrading the rear soon.
Old Oct 23, 2012 | 06:52 PM
bstuby's Avatar
I just swapped out my 3200 for a 4000 also. Been saving for a 9in for a awhile now, so I'm not to concerned if it breaks or not.
Old Oct 23, 2012 | 06:57 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Past setup-Yank SS3600 / 4.56 10 bolt / Nitto 315-35-17 Drag radials-no problem. Currently Yank SS3600 / 3.23 10 bolt / Nitto 315-35-17 Drag radials-no problem.
Old Oct 23, 2012 | 06:59 PM
nj02z's Avatar
I also have a Yank 4000ss with a 10 bolt 3:73 gears.jusy cut 1.61 60 ft times with DRs.So far so good but a S60 will be on the way sooner than later.
Old Oct 23, 2012 | 08:53 PM
bigantws6's Avatar
I have a 4000stall slicks and 3.23 with 10bolt
Old Oct 23, 2012 | 08:58 PM
SF 1HOTLS1's Avatar
i had a 10 bolt with 373 gears and a yank ss 3600. car made 480 on nos. went 10.9. lasted a while but i did go through 2 sets of gears. if u dont plan on putting drag radials on it you should be fine for a long time.
Old Oct 23, 2012 | 09:13 PM
Kingc8r's Avatar
Mine ate a pinion gear (3.73s) after 3 months lol.
Old Oct 24, 2012 | 07:11 AM
c0ncEpT's Avatar
No problems here. Stock 10 bolt with 3.73's. 1.6x 60'
Old Oct 24, 2012 | 11:59 AM
Mystery Bird's Avatar
3600 and stock 10 bolt here, pulling both front wheels 6-8 inches with 1.5x 60's for three years now. Probably 100 pass's at the track. 10 bolt has welded tubes to center, solid pinion spacer, Eaton posi, and rear cover.
Old Oct 24, 2012 | 04:41 PM
texas99Z28's Avatar
Thanks for all the replies ya'll! Makes me feel better. Dont get me wrong, I will be saving for a RE assembly. Good to know I can still have some more fun while I'm waiting to save enough up!!!!
Old Oct 24, 2012 | 05:59 PM
NVR_SPDS's Avatar
Ive had 2 4k stalls, and am currently running an SS3600, with 3.73s and girdle on my 10 bolt. Im mean to it, and it doesnt make a sound.
