Big cam shifting problems?
Seems like its hanging the 2 to 3 shift 1st pass hit the limiter hard 3 times(dat.dat.dat.) then shifted (I never let off).
2nd pass we lowered the 2-3 shift 3 mph and it did the same thing hit the limiter hard 3 times then shifted
I was reading a diff. post about a deep pan helping and also speed sensor on the tranny?
Thanks for any help.
No sense in reving it when its not makin power.
I finally got it to shift into 3rd with out hitting the rev lim. I lowered the shift mph by 4mph and increased the rev limiter to 6750. It work for me. but it Still hit the limiter on the 1/2 shift. I ran 11.51 on that run.
I think I told Jeff about it, Then the converter took a crap. have to start over now.
rob
There is a table that allows you to adjust the delay. You might try reducing the delay time.
Also be sure that you are getting clean runs. Spinning a bit can mess everything up.
FWIW:
1) my shift points on the street do not work at the track with ET streets. I have to run lower shift points for racing, otherwise I bang the limiter at the track.
2) I have to race in OD. If I race in D, I have the same problem as you on the 2-3.
