4l60e/700r4 tail shaft
Old Oct 31, 2012 | 12:06 PM
ZQ8Dude's Avatar
Default 4l60e/700r4 tail shaft
I'm looking at putting a 4l60e into my 73 duster(using a tf3 kit to get rid of electronics for the time being)
I've been looking at google images and it looks like there are two types of 2wd tailhousing. Ones that have what looks like a speedo gear housing? and one without.
large circular housing:
http://paceperformance.com/images/T15186553.gif
no circular housing:
http://www.rebuilttransmissionsforsa...ransmissio.jpg
Are these interchangable and would that tailshaft interchange onto a 700r4?
Asking because with a mopar i'm dealing with a torsion bar crossmember and that circuler housing makes for a lot cutting/fabrication to fit the transmission. Where it looks like the narrow housing will fit with little/no cutting.
Old Oct 31, 2012 | 07:41 PM
Nova 404's Avatar
You can put a 700r tail housing onto a 4l60e but you will need and adapter plate such as the JTR kit.I have my 4l65e set up this way but do not have it in service yet.
The only down side I see is it moves the mount back a few inches,going in a Mopar your will be fabricating a crossmember any way so it should not be a big deal
Old Jan 23, 2013 | 06:35 PM
fox12303's Avatar
Nova404, i've seen the aftermarket tail housing kits sell for $550 that do the same job as what you've shown above. How much would all the parts cost that you've shown in your first picture above?
Thank you.
Old Jan 23, 2013 | 08:59 PM
Nova 404's Avatar
It was bought as a kit and retailed for $538 to my door a bunch of years ago,they are @ $550 now plus shipping
Old Jan 23, 2013 | 09:42 PM
joecar's Avatar
In your 2nd pic, the speedo bore is on the other side of the extension housing... look at the small bore in this pic:
Old Jan 23, 2013 | 09:44 PM
joecar's Avatar
Also, take note of the number of mounting bolts (6 vs 4).
Old Jan 24, 2013 | 06:40 PM
joecar's Avatar
Originally Posted by fox12303
This looks like a TH400 and the circular housing is the governor cover.
He was actually referring to this (green arrow in attached)... [ it looks like a 700R4 if you zoom in ]
Attached Thumbnails 4l60e/700r4 tail shaft-t15186553.gif.png
