Full manual 4L80 swap
Old Nov 9, 2012 | 01:42 AM
streetz28's Avatar
Default Full manual 4L80 swap
what all would i need with a full manual 4l80 to swap it behind a 6.0 in a 6 speed camaro. With a full manual trans it shouldnt require any electronics but what parts will i need. I know ill need a shifter, cooler, converter and crossmember. Now where do i find a shifter and will i need a different driveshaft or will my current one work???
Old Nov 9, 2012 | 09:34 AM
Jake's Performance's Avatar
Sounds like you have it planned pretty well. USUALLY you can swap the yoke on your existing driveshaft and it will work from a T56 to 4L80e and it will work.
Old Nov 9, 2012 | 01:52 PM
streetz28's Avatar
Okay what shifter do i need to run.
Old Nov 10, 2012 | 07:07 AM
cabel1's Avatar
I put a factory auto shifter in mine.
Old Nov 10, 2012 | 07:31 AM
+badss+'s Avatar
im putting a b&m pro stick in mine the stocker sucks too easy to go 1st to 3rd with a stock shifter. i bought the pro stick used and bought a 4 speed gate pattern for it.
Old Nov 10, 2012 | 05:06 PM
MUSTANGBRKR02's Avatar
Agree with above.
Old Nov 11, 2012 | 03:25 PM
streetz28's Avatar
Thanks guys.
