4L60E stall question
The car has picked up .25 in the 60ft .62 in the 1/4 and 1.5mph.
With my mail order tune it has great drivability.
My car has 130,000 miles on it and I didn't rebuild the tranny,if you already have a problem it will amplify it.
I bought my TA with 120,000 miles and have over 300 dragstrip passes on her and about 60 with the converter installed.
BTW the converter is used.
the converter wont flash straight to 3600 unless i give it wot. if you give it gas gradually itll be like normal for the most part til you really get into it. it will need a little more gas to move from a stop but not much more than stock.
Yes itll generate a lot more heat because it is unlocked until you get to a certain speed, and the converter is basically shearing the fluid, thus raising tranny temps. once it locks up itll be just like stock and wont get as hot and mpgs will be better because its operating at a lower rpm than when its unlocked.
look on youtube for some videos of people with converters, theres a ton and thatll give you a better idea of what im saying.
Id call the converter company you plan on going with and telling them about your goals and mods, and theyll give you a good recommendation. Any of the sponsors who deal with converters on here do a good job and would be able to help.
personally Ive been looking into the torquer v2 for my car and it would work well with my converter.
Whatever stall speed you pick, you'll want a 9.5-10" converter with a good clutch. Have a Transgo shift kit installed when the tranny's out and get tuning done to get your shift characteristics where you want them.
if you plan on going with serious power down the road 600/600 + you may as well go ahead and contact jakes performance. grab a good trans, and never worry about it again.
its not nearly as hard as its made out to be.
you just need a crossmember
a hammer to knock the **** out of the tunnel
a different yolk/linkage for the driveshaft to mate it to the 10 bolt (if thats what your running
and a segment swap/controller/or slow67 has a way to repin the harness to make it work.
you will most likely never be able to break that trans.
RPM/FLT/Jakes are the way to go. and not in that order.
Greg
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
