4l60e to deadhook 450whp
I've finally got the car running well making 450+ through the 9"...but I need a trans. I want to stick with a 60e and am just wondering how far I need to take it. Basically, I'm thinking something like the rpm level 5/6 or equivalent and wondering if I need a 300m output shaft. I'm running a loose circle d 3200 stall (flashes to 4200) and just wondering if it is advisable to spend the rather exorbitant $500 extra for the hardened shaft or any other extra bits. Please don't say go 80e as I am not interested in one for this car.
Dyno thread here if anyone wants to see
https://ls1tech.com/forums/showthread.php?goto=newpost&t=1601398
https://ls1tech.com/forums/showthrea...post&t=1601398
This is a transmission I did for my girlfriends brother, he put down 470 rwhp in a ss4000 converter 4l60e heads cam LS3 swap and a stock 10 bolt with 3.23 gears....
Don't do a transbrake...if this car can cut 1.4 60' leaving from IDLE with a 3.23 gear..well nuff said
Also look like this 60E gives 6 speed cars trouble from rolls
I have done a lot of builds similar to this black car, all going strong. I have the same build in my truck with the exception that I tried to "soften up" the feed holes in it, shifts like butter at part throttle, nice kick at WOT, if this 400hp+ nitrous 60e can live up in a lifted 4x4 TURD, then a lightweight 450hp camaro shouldn't be much issue, 2 years strong daily driving, daily streetracing...LOL 3600 stall FTW
I guess my question boils down to: given that I will use a 60 and plan to hit it as hard as I can on stickies is the hardened output shaft ('that appears to be the only difference for rpm level 5/6) worth the extra dosh, which is $500...or should I consider other specific upgrades?
...and yes, the 2-3 shift is very borderline as it sits today. I've flared through the shift and banged the limiter twice. I added one cup of fluid and the flare is gone-ish, but the shift is getting sketchier by the run.
If its a BILLET shaft, then yes, nice upgrade...hardened shafts are also nice just half price then the billets..the black car above has the hardened output...the output shaft usually breaks on VERY hard 1-2 shifts...I've seen a stock shaft break at 290 rwhp due to the b&M shift kit that was installed, overlooking their instructions they remove the 1-2 acc and block it off...wow big no no...on that same car I removed that shift kit, did my own tricks, did a budget build with stock output and 2 years later went 1.39 60' leaving off idle 530 rwhp ..stock output can live at 450hp if the converter is loose and the 1-2 shift pressure is perfect, but I always recommend hardened output at 400+ and billet output at 550+ just to be more on the same side
They are guys running a 800rwhp plus through the same trans. You wouldn't have to think about the trans again. Pm if you are interested.
