4l60e swap
Old Nov 24, 2012 | 09:53 PM
ROUDA's Avatar
Default 4l60e swap
I have a 95 z28 , the trans needs rebuilt so I was thinking of picking up a used one for a quick fix and rebuild the one I have . my question is I came across some threads where ppl saying that the 95 year is a odd ball year and that is the only year they used pwm or something like that.
so that being said has any one swapped a different year trans in to a 95 and was there any mods needed to do to make it work correctly? I see alot of 4l60e trans in my area none are 95. What should I do thanks.
Old Nov 26, 2012 | 10:49 PM
ROUDA's Avatar
bump it hoping someone has some expi with this
Old Dec 2, 2012 | 03:10 PM
pricesgarage's Avatar
You are correct 95 is a one yr only swap due to the electronics finding a used unit is going to be hard if u use a 96 or 97 ,you need to use the valve body seperator plate, and wiring harness and soleniods. Most 4l60 e clutch failure is from worn valves in the valve body so not recomended have yours rebuilt were are you located i have a tranny shop in west virginia
Old Dec 2, 2012 | 08:56 PM
ROUDA's Avatar
im in Pittsburgh Pa
Old Dec 2, 2012 | 08:59 PM
ROUDA's Avatar
are you saying that its not recomended to have my trans rebuilt
