Another one of those: Converter brand choice between CircleD, Yank, and FTI
Jake is referring to one of our converters. It was a 310mm 13” multi disk converter. Not entirely sure what happened. We built him a stock style unit with a multi disk upgrade. We had an internal communication problem and our builder assumed it was just a stock type unit with a multi disk. What we did not do is use a furnace brazed turbine and re-enforce it with TIG welding. There was not a converter failure, it was simply in for a cut and clean. We have since upgraded Josh to a Dodge/4L80 conversion and it is working very well with his power and weight. We made a mistake, took care of it and made the customer happy.
I have heard great things from all 3 brands mentioned..i happen to have a circle D 5c..I luv it! before that had a TCI..HUGE improvement going with the 5c..feels tight but hits hard when mashed
There are dozens of good converter companies in the industry, who are turning out product that is as advertised, works well, and I wouldn't hesitate to refer a customer to.
TCS, Hughes, PTC, Coan, Trans Specialties, Precision Industries, Pro-Torque to name just a few.
I have an issue with above converter because the whole story reeks of BS. Anybody with half a brain and a pulse should recognize that they are putting a billet cover triple disc on a converter, it's probably not for light duty usage. I doubt this one "slipped through" particularly after speaking with others in the industry.
I'm glad Josh is happy with it now. He never would have known it was substandard until it rolled the fins over had we not had to do a cut/clean.
I like to refer customers to smaller innovative businesses and if they are in Texas, that's even better. However this is one company we no longer recommend and have even considered not offering a warranty on our units when they are used.
I wasn't going to openly post it but it is obvious the "cat is out of the bag".
I have *never* heard this happening with one of the companies Jake posted ^, and one more reason why I will keep recommending PTC well above the majority. I will never step in a thread and say don't buy XXXX converter, especially if it is a sponsor, but if asked my opinion I will give it and back it with the reasons, making sure not to step on toes.
PTC is badass. I think Koolrayz is running there converters and has around 1% slip....making it very efficient. He received it that way the first time.
They did one for my 4l60e cam car, and it dropped almost a whole second leaving off idle, and was getting faster every weekend. Had I built the slipping 4l60e, I am sure it would have really been able to show what it was worth.
I can honestly say, those guys are obsessed with racing.
Its between them and FTI this monday as to whom I will choose. I got some mixed vibes/attitude from other sponsors when questioning why the spec'd a single for 850-900rwhp for lockup pulls in the 1/4.
PTC has great customer service---
Circle D does---
and so does FTI----
its really hard to go wrong with any of the three.
So does Jakes. Some of the best and most innovative aftermarket part manufacturers in the world are sponsors on this site no doubt.
Circle D does---
and so does FTI----
I had the pleasure of speaking with Greg at FTI in person today at the PRI show.
Those guys are definitely doing great things and we haven't done any business with them in the past but we will be in the very near future for some of our transmission parts that they have the manufacturing capability to produce quicker than we do.
I will also let the "cat out of the bag" a bit prematurely and say we will very likely be making our own converters in house in the near future at Jake's Performance.
We work with two excellent converter builders currently but sometimes the capability to do them in house would cut down on lead times and possibly cost.
#32
#34
fti 4500 here. I couldn't be more in love with the convertor, it was everything i was hoping for and more. the car is a tt 383 th 400 setup. the car will creep foward at idle just like a normal car, it will even go up slight inclines. It can accelerate in third gear and keep up with traffic at 1800 rpm. When i go wot it hits like a train and the car takes off like it was shot out of a cannon. You can't go wrong with an fti, just let them know what your setup is and have them custom make it for your car.
On a side note I originally wanted to go with a yank ss 4000 and my builder didn't want to go in that direction. he said they only use fti and I can see why now.
#38
LS1Tech Co-Founder
Yes. We have seen a few less than satisfactory converter builds from various vendors.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
FWIW I ran five different brand converters when I ran 4th gens, and they were PI, Fuddle, Yank, PTC and ATI. Half of those were TH400 applications, but I had very good experiences with Yank for 4L60E applications. I'd consider trying Circle D and FTI based on friend's experiences.
#39
I no longer own LS1Tech but these kinds of posts are not in the spirit of the site that I co-founded almost 12 years ago. ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I see the transmissions and converters from almost every vendor in the marketplace on some level. I often work with others in the industry either buying parts, referring customers, or selling them parts.
I referred the above customer to Circle-D for the above converter build. It was a fairly expensive converter, over $1300 as I recall.
To open up a converter from a supposedly respectable company and find it was not what the customer paid for is a slap in the face of not only the customer but to my company for referring the customer.
This converter is equivalent to me building a 4L80E with billet shafts, deep aluminum pan, and all the bells and whistles, and using a worn out pump and used clutches.
It may "work" but it's not what the customer paid for or what it was advertised to be.
If that is acceptable to you or others, that is your right. That isn't how I conduct business and I feel like the consumer has the right to know about the product they are buying.
Most people don't ever get to see the inside of the converter they buy.
I didn't start the post, I didn't state any names. I simply posted a picture of an expensive converter that wasn't as advertised and that's why I recommended going with FTI over any others mentioned.
I guess if it's any consolation, the above converter and company isn't the only one we've seen built without the advertised upgrades.
#40
The reason I posted about Yank, CircleD, and FTI is they seem to have really good offerings for street/strip 4L60E applications and are well-respected on the board. All are about the same price and have similar features/warranty. PI is another, but I know their converters run a little looser than advertised but tear it up at the track.
