Transmission acting weird
I checked the trans fluid and I see where it is slightly wet at the hot level,is that where it should be? There is alot at the bottom of the dip stick,which should be right,since gravity will pull it to the bottom.
There is also a clunk at times if I get onto the throttle which appears to be coming form the underneath the area of the center console storage.
Let me know what you guys think. It's on my 97 Z28.
