3600 stall
-OEM 1800 & OEM 3.23 for 4 years
-TCI 2800 & OEM 3.23 in 2006
-TCI 2800 & 4.56 in 2007
-Yank 3600 & 4.56 in 2011
-Yank 3600 & OEM 3.23 in 2012
-Yank 3600 & 3.42 or 3.73 in the spring of 2013
Honstly though I really dont think its much of a difference. I only lost 2-3mpg from the last build and I dont blame the 3.73 very much for it.
This calculator might help:
http://www.wallaceracing.com/gear-speed.php
Enter:
26 (This is your tire diameter)
.7 (This is OD ratio in 4l60e)
3.23
3.42
3.73
This will show you RPM and MPH for the different rear ratios.
I dont think 323 to 373 on a stalled car is going to make 1/3 the difference the stall will make as far as et drop , with all your highway driving put the gear swap money into another mod youll be happier. , wait till the rear has an issue to change gears ( let sleeping dogs lie)
