LT1 Fbody converter = C5 converter
Old Dec 12, 2012 | 05:05 PM
stngh8r's Avatar
Question LT1 Fbody converter = C5 converter
I have heard this in the past. Can anyone clear the doubt, that a converter from one will bolt up to the other with no modifications?
Thanks in advance
Old Dec 12, 2012 | 05:45 PM
Circle-D's Avatar
You are correct.... Even though the Corvette went to an LS motor in the C5, it still used the LT style converter. It is a direct replacement. In 2005 the C6 went to a LS style, then in 2006 they went to the 6L80 setup. Hope this clears it up, any more questions let us know.
Chris
Old Dec 12, 2012 | 06:23 PM
stngh8r's Avatar
Fantastic. Thank you Chris. BTW, I have one of your converters.
Old Dec 12, 2012 | 07:35 PM
Circle-D's Avatar
My pleasure and thanks!!
Chris
Old Dec 12, 2012 | 08:09 PM
HighMileageC4's Avatar
I can also verify that my 96 Lt1 corvette used a C5 Converter.
The writing on my Yank was "SS3200 LT1/C5"
The LT1 Fbody and LT1 (or L98) Corvette should be the same with the smaller diameter input shaft and TCC O Ring for a 700R4 or early 4L60e.
