Trailblazer torque converter
Old Dec 18, 2012 | 10:00 PM
gmcyukon's Avatar
Default Trailblazer torque converter
Will a torque converter from a 6 cylinder fit in an 4l60e from a 2002 seirra with a 5.3 and I was also told that it has a higher stall also is that true
Old Dec 18, 2012 | 10:53 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Yes it will fit and it will stall more than the stock converter your Sierra came with because it was designed for an engine with less TQ/HP than the Sierra. It will increase the stall rpm and improve performance, but I would not put a lot of power behind it for integrity reasons.
A custom or modified budget converter for your application would be a better option IMO.
A TB converter will give you appx a 3/10 ET reduction where as a good custom converter is worth an easy 6-7/10 ET reduction as well as long term durability.
It's no mystery that I favor and recommend Circle D Specialties. I have ran their converters in all of our bracket cars and trucks and they have never let us down.
GL
Old Dec 18, 2012 | 11:39 PM
gmcyukon's Avatar
I'm not putting much power to it . I'm just doing a cam install and want bigger stall!! And other bolt ons
Old Dec 19, 2012 | 12:41 AM
carlsonauto's Avatar
Dont get extremely crazy with it and you will be fine with the t/b converter.
Old Dec 19, 2012 | 09:34 AM
Circle-D's Avatar
Yes, they are correct it is a direct bolt in replacement. I am a big fan of the 278mm for a DD performance setup. It does have it's pros and cons though. If you want to shoot me an "Ask Chris" - link in sig - be glad to help you out.
Chris
