Shift RPMs
In a safe location with plenty of room in front of you try this:
1. With trans in drive, hold the brake firmly with your left foot.
2. Over a period of 2-3 seconds, gradually increase throttle until the revs stop climbing while the car is NOT moving. The RPM where they don't climb much more is the approximate "stall speed".
3. Don't do this for more than 3-4 seconds because this test rapidly increases the trans fluid temperature. If you have to repeat, give it a good 15-30 minutes to cool back down, preferably with easy driving.
Again, this is the approximate stall speed, but should be within 500 rpm.
I'm not an expert, so watch for corrections or additional comments too.
The settings are pretty much by driver preference which makes it nice to have HPT to mess with them
I set mine just this week, and I like the change. Mine was getting into 3rd gear by 20mph at light throttle.
My first attempt had 1-2 shifting too late, didn't like that at all.
So now I have the 1-2 set to 14mph, and the 2-3 set at 25mph and 3-4 set to 35 mph.
I have a 3600 stall and this kept it from just stalling the converter all the time.
BTW....you can get close on the stall by the method Vedit stated, but it is highly dependant on how good the rear brakes are.
Ron
It will vary depending on your throttle position...
It is not a "Fixed value" for all throttle positions...
it does not do part throttle shift by RPM's, it does it by throttle position and MPH
at low throttle position it shifts into the next gear sooner than at High throttle positions..
its determined by your tune and a table that has multiple values for all gears
WOT is determined by several tables... a Minimum MPH to reach before it shifts, and a desired RPM to shift at once that MPH has been reached...the MPH table is primarily used to determine when to downshift to a lower gear at WOT
there is also a desired shift time table, which is a learning table that makes your shfts more varied depending on other sensors... this table can be zero'd out to make it always shift the same regardless of other variables its using for shift calculations.
the only way to know exactly what it commands the shift at, is to either log data and plot it, or to read the tune and look at the table
https://ls1tech.com/forums/automatic...tm-w-pics.html
thanks
