Converter bolts.. how to remove them in the car?
This way the flexplate doesn't move when I torque the bolts.
(Or have a helper with a 24mm socket and large wrench on the crank bolt.)
Also I already have at least half of the spark plugs removed before I remove the header. This makes it much easier to turn the crank.
If you have to install washers with the converter, you will have to turn the crank at least two revolutions. First install the bolts fairly loose so that you can fit a washer for the next bolt, but not so loose that it hits/binds on the engine block.
