What year 4L80E?......
Old Jan 10, 2013 | 07:52 PM
cbrodine's Avatar
Default What year 4L80E?......
...can I use for my 2004 LQ4? I just got '04 LQ4 out of a Denali and I'm trying to find a 4l80e for it. I've seen lots from the mid 90's on up but don't know what year(s) I can use with my '04 LQ4....can I use an older one? I'm very new to the LS series and the trannys that go behind them.TIA
Old Jan 10, 2013 | 08:17 PM
carlsonauto's Avatar
The older ones dont have the top bell housing bolt like the newer ones do. There are a few other differences, most of which dont really matter but the big difference that I know of that I am unsure if it matters is the EPC solenoid is different. If I remember correctly it changed in 2003 but I have never tried to swap between the two different styles and dont know what is involved if anything.
There are a few guys on here that know the 4L80s inside and out and perhaps one of them will chime in..
Old Jan 10, 2013 | 09:22 PM
Smo's04Gto's Avatar
Search Daniel son........ and you'll find all the info you need.
https://ls1tech.com/forums/automatic...-need-get.html
Old Jan 11, 2013 | 01:15 PM
cbrodine's Avatar
Originally Posted by Smo's04Gto
Search Daniel son........ and you'll all the info you need.
Thanks Smo...that helped. I just found one out of a '99 2wd 3500 truck.
Old Jan 11, 2013 | 01:51 PM
Blackpanther99's Avatar
Older cores have better overdrive
Old Jan 11, 2013 | 05:48 PM
SnIpEz's Avatar
I'd shoot for a 96 or lower, they tend to be cheaper and have a strong OD roller clutch.
Old Jan 11, 2013 | 07:58 PM
Agreed^ I gave a call to Jake's and they preffer the older cores for the bette OD
