2002 Trans Am 4l60E Help
Old Jan 17, 2013 | 04:06 PM
Nighthawk38's Avatar
Default 2002 Trans Am 4l60E Help
I just purchased my first Trans Am; and I am new to the motor and tranismission. I have a problem, the car runs a 323 rear end and I am cruising around at 65-70MPH running 21-2300 RPM. I do not think that I should be running that high RPM. shouldn't the torque converter kick in and bump my RPM's to around 17-1800? This is a stock LS1 with the LS6 intake, only 73,000 miles.
If I am not over reacting about the RPM's are there any suggestions for me to look at before I pull the Transmission? I had a MAF code come on but I found that problem and fixed it.
Old Jan 17, 2013 | 05:23 PM
mrvedit's Avatar
Moderator
I agree that your RPMs seem too high.
I suspect that your converter's lockup clutch (TCC) is not engaging, as you suspect.
Perhaps someone has a better way, but I can think of two way to test if your converter is locking.
1. On the hwy, give a modest amount of gas (extra 15% throttle) and watch the RPMs. If they immediately jump before the car speeds up, the TCC is not engaged.
2. On the hwy, give about 60% throttle to speed up e.g. 10mph then easy the throttle and watch the rpm. If you see it stable and then drop by 200-300 rpm, that is the TCC engaging.
Generally these cars give a 1870 code if the PCM tried to engage the TCC, but detects via RPM slippage that it is not engaged.
First be sure there are no codes in the PCM, especially not MAF codes. Various codes will cause the PCM to never engage the TCC.
Old Jan 17, 2013 | 08:35 PM
farmington's Avatar
Are you absolutely sure it has a 3.23 gear? if you had a 3.42 that would be about right. Wht size tires does it have on the back wheels, tire heights will affect rpm's a lot.
Old Jan 18, 2013 | 05:58 PM
Tires size is 245/45 17 the car calls for 275/40 17. The bin calls for 3.23. I am not sure it hasn't been replaced but this car is stock everywhere else,I am not sure why they would change the rear and leave the rest
Old Jan 18, 2013 | 08:37 PM
joecar's Avatar
275/40R17: tire diameter = 275*.40*2/25.4+17 = 25.66" <-- what should be on car
245/45R17: tire diameter = 245*.45*2/25.4+17 = 25.68" <-- what you have
at 65 pmh: RPM = 65*336*3.23* 0.696/25.68 = 1911 rpm <-- in 4th with TCC locked
at 70 mph: RPM = 70*336*3.23* 0.696/25.68 = 2059 rpm <-- in 4th with TCC locked
my calculations ^ show you're in the correct range.
edit: sorry, I ballsed up the tire diameter calculation, see my corrections.
Old Jan 18, 2013 | 08:42 PM
joecar's Avatar
You can tell when TCC is locked while cruising at freeway speed...
as you release and reapply the throttle the displayed rpm does not move, and as you increase throttle mph starts climbing noticeably while rpm climbs very little.
Old Jan 22, 2013 | 12:11 PM
Originally Posted by joecar
275/40r17: Tire diameter = 275*.40*2/25.4+17 = 25.7" <-- what should be on car
245/45r17: Tire diameter = 245*.44*2/25.4+17 = 25.5" <-- what you have
at 65 pmh: Rpm = 65*336*3.23* 0.696/25.5 = 1925 rpm <-- in 4th with tcc locked
at 70 mph: Rpm = 70*336*3.23* 0.696/25.5 = 2074 rpm <-- in 4th with tcc locked
thank you for the equations; i will use these.
Old Jan 22, 2013 | 12:22 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
If you're going by the factory tach and speedo,my tach indicates about 150 rpm higher than actual rpm(off ScanGaugeII) and sometimes speedometer is off,mph is best read/indicated by/with a GPS unit.
 Michael S. Palmer
Old Jan 22, 2013 | 01:07 PM
joecar's Avatar
Sorry, I fubar'd the tire diameter calc (used .44 instead of .45)...
I corrected it and the subsequent calcs, see my numbers above (hopefully I didn't fubar it again).
Old Jan 30, 2013 | 02:12 PM
The car is not throwing any PCM codes and it appears that the TCC is not engaging. My next step should be to pull the Pan and change the solenoid?
Old Jan 30, 2013 | 02:14 PM
I put a GPS on it this Morning and the car and GPS were about 1 MPH off. with the GPS showing faster then the car.
Old Feb 7, 2013 | 11:05 AM
shepss217's Avatar
turn the tires and count how many times the yoke spins compared to 1 full tire rotation, i can hear the lockup on my car kick in around 45-50 mph, sounds like it just shifts 1 more time
Old Feb 7, 2013 | 11:10 AM
Image98's Avatar
decent know how in here. LOL
Old Feb 13, 2013 | 06:01 PM
shepss217's Avatar
thats what we do!!
