Help!!! TRANS PAIN!!!!
at 10 mph a alarm would go off stayed on until would stop.also at 10mph.would shift hard drove around 17 miles to work was able to drive 70mph.at around 2100rpms.
alarm going off the hole way also brake light blinking consistently that could be the alarm problem not sure. took to auto zone code came up p1870 said was shifting into fourth gear with slippage or tcc then was driving home and became worse as to where in order for me to drive i had to put into od. made it to my brothers down the road.we checked the fluids,fluids good and noticed the fluid was not hot. so then we drove
approx. 1 mile and the truck will not pull itself had to tow home. took off the cables to reset ecm. held wires n and p together then replaced no change. thank you.
https://ls1tech.com/forums/automatic...ssue-help.html
It generally means the lockup-clutch of the converter is slipping, but
in your case I wonder if the converter is completely shot because you have no more forward motion.
BTW - Once the PCM set code 1870, the trans will shift extra-hard.
Please confirm that your truck no longer drives forward.
Does the truck drive in reverse?
A simple "approximate" way to check the pump is to first check the fluid level with the engine off; then check the fluid level with the engine running; if the pump is working the level should go down about an inch. The definitive way to check the pump is with a pressure gauge hooked up to the pressure port on the trans.
I'm guessing that the internals of the converter self-destructed, first taking out the TCC, but then taking out more.
I'm no expert and don't know much about converter problems. I'm hoping someone else can either confirm or correct me.
