4L60e LT1 Issue
Going down the road crusing about 60 in OD you can floor it and she wont down shift. same goes with 3rd gear
My guess is that that the PCM is not commanding a shift because of a sensor problem. Make sure your throttle sensor, speed sensor, MAP and MAF(?) are working properly. Have the PCM scanned for codes.
The car runs really rich, almost smells like as if it has gas running through the exhaust, i thought the EVAP was undone again but it wasnt, it just runs crappy and im slowly thinking either the person who owned it before us molested the car so bad that they either "Tuned" it and it went wrong or the PCM is failing.
See the trans was runnning fine up untill about a week ago. i dont even know where to start with the motor, both head gaskets have been replaced and the only mods i have seen done so far is the fans have been cut, got to hard wire to a switch
and the exhaust had the cats cut with flowmaster dumped after the axel You didn't mention if the MIL (Check engine light) is on; if it is, correct that first.
If tuned, either the MIL was disabled, or the code was completely disabled. I suspect there are codes.
