700r4 question
Old Feb 8, 2013 | 06:28 PM
Big bird55's Avatar
Default 700r4 question
i was wondering if there is a way to bypass the lockup features on the 700r4.
Old Feb 9, 2013 | 11:03 AM
72blownvert's Avatar
Yes there is. Get a non lockup valve that goes in the pump then remove the ball and capsule that is in the input shaft.
Old Feb 10, 2013 | 06:23 PM
pricesgarage's Avatar
if its 1984 to 93 u can leave it unpluged they sell a valve that goes in the pump but it will shift fine with out being plugged in if you do a lot of highway driving it will run hotter without a lock up but with a good cooler you will not get into a over heating problem u can wire it on a toggle switch though pretty easy
