96 4l60e to 01 5.3
Old Feb 12, 2013 | 08:54 AM
dalooboyz's Avatar
Default 96 4l60e to 01 5.3
ok i have been doin a lil research and got down that i need a spacer kit and bolts to mount the torque converter...etc. the 96 trans is a built 2wd out of a truck. was wondering if anybody had any insight on if that tailshaft will bolt into the 84 camaro, driveshaft...etc. also wondering if i will need to change housings to upgraded vss. i know i will need to change housings because of my torque arm. basically wondering if a newer vss will spline into that tailshaft.
