Th350 help needed !
Old Feb 18, 2013 | 01:22 PM
Jamie22's Avatar
Default Th350 help needed !
Bought 93 mustang with ls1 and th350 trans. Having issues with it and need some help. Its delaying goin into 2nd gear but when it does go in it does just fine. Fluid is good and not burnt nor low. Check vacuum line also. Any ideas?
Old Feb 18, 2013 | 02:16 PM
MM98's Avatar
Is it delayed at part throttle shifting or wot?
Old Feb 18, 2013 | 02:22 PM
carlsonauto's Avatar
Is it only having issues with the 1-2 shift or is the 2-3 late too?
There isnt really a lot that can go wrong in a TH350 to cause issues with 2nd. IF it shifts gorrectly into 3rd I would say you can pretty much rule out a vacuum modulator issue.
Some things it could be are 1-2 accumulator leaking, 1-2 shift valve sticking, intermediate sprag not functioning properly, or possibly a governor issue but I kinda doubt that.
Old Feb 18, 2013 | 02:25 PM
Also what does it have for a valve body? guessing its not manual since you said you checked the vacuum line but just making sure..
Old Feb 18, 2013 | 07:05 PM
Jamie22's Avatar
Just doin it on 1-2 and most time at wot. Has a manual valve body in it.
Old Feb 20, 2013 | 10:21 PM
Jamie22's Avatar
Come on guys need some help
Old Feb 22, 2013 | 07:44 AM
pricesgarage's Avatar
it sounds like clutch clearence is high or the 2nd gear clutch pack is burnt pull the pan look for material r burnt fluid
Old Feb 22, 2013 | 08:41 AM
72blownvert's Avatar
Check the linkage adjustment.
