flexplate, starter issues.
Old Feb 25, 2013 | 04:49 PM
parkschrow's Avatar
Default flexplate, starter issues.
Just swapped 2001 4L60E with 1997 v6 4l60e. I used a spacer. Now starter doesnt make contact with flexplate. I have a curved flexplate
Old Feb 26, 2013 | 01:18 PM
Taspeed's Avatar
did they come from the same engine? 3.4, 3.8, 5.7 etc? I'm not sure if the flexplates are the same from engine to engine. Flexplates may be 168 or 153 tooth. I'm trying to verify the same info.
Old Feb 26, 2013 | 05:41 PM
forcd ind's Avatar
you prob need the 4L80E FW-did you put a spacer bet the crank and FW-you cant do that with a curved FW
