prndl/neutral safety switch
Old Mar 3, 2013 | 07:57 PM
yourownself's Avatar
Default prndl/neutral safety switch
so, i'm installing my bastard setup, and long story short, my harness is from an '05 Trailblazer, and my transmission is from an 02 Camaro.
Speartech left the pigtail for the transmission mounted PRNDL switch on the harness, leading me to believe that i need to use one.
Has anyone mounted a PRNDL switch to their older transmission, or am i going to need to source a shift selector for a newer transmission?
TIA.
Old Mar 4, 2013 | 08:28 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
We leave it on for convenience. You can usually get a backup light signal and neutral safety wire out of it.
In your case I'd probably just cut it off or tuck it away and get those signals from your shifter or aftermarket add-on.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Mar 4, 2013 | 08:32 PM
will the ECM be looking for a signal from that sensor?
Old Mar 4, 2013 | 08:49 PM
Speartech's Avatar
No, it will not.
__________________
www.speartech.com
