700R4/4L60 Questions
Old Mar 4, 2013 | 10:45 AM
jkr2wld's Avatar
Default 700R4/4L60 Questions
I have a 93 Camaro, A4 700R4/4L60.. Have 115,000 miles. I want to put a Transgo Shift kit/ Hayden Tranny Cooler and possible Corvette Servo (Which I'm still not sure if it has one or not) will it hold up with the Shift Kit? This car was very babied before it got to me. Garage Kept. Last owner probably put 20,000 miles on it in 10 years. I Don't rag on it every day like I used to. It is a DD. When I changed the oil, the paint on the transmission still sparkled! looked very neat/clean inside, no metal. What do ya'll think?
Old Mar 4, 2013 | 12:33 PM
lt1-xjs's Avatar
As long as the trans is in good shape it should'nt be an issue. I installed the shift kit and Yank ss 3600 8 years ago. I run the modified Transgo kit from Probuilt Automatics, it comes with the Corvette servo but you should already have one. The Hayden 516 cooler has worked well for me.
Old Mar 5, 2013 | 07:58 AM
pricesgarage's Avatar
if the trans is a origional it should have a corvette servo 93 was the best of the 700r4 s if its working good put a cooler on it and go if its stock and working correctly full throttle upshifts should be firm i would recomend putting a sonnax .500 boost valve in the pump u can do that with the pan off
