Convert/adapt 29 spline 6L90?
Old Mar 4, 2013 | 03:27 PM
albersondh's Avatar
Default Convert/adapt 29 spline 6L90?
For reference the 2wd 6l90e is a 36-spline output, yokes are available: like this one. The 4x4 6l90e is a 29-spline and I cant find a yoke....
Got a 6L90E from an 08 4x4. Wanted to run it in my 1-ton 4x4 but the output on the trans wont mate to the x-fer I want to run (NP205).
So its a no-go in my 4x4; shifting gears, I want to use this in a car. I need to get a yoke on the output. Should be pretty straight forward deal, the output is 29 spline, 1.452"-dia, and 2.5" of spline. Soooo just need to find a 29sp slip yoke (or 28-on-29)? I cant find one.... I think the 2wd 6l90's are 36 spline Any ideas?
What I want to happen....
Old Aug 30, 2025 | 10:20 AM
RodAlfaro's Avatar
Hola amigo, pudiste resolverlo? Yo tengo exactamente el mismo problema
Gracias
