Need help/opinions on trans
Old Mar 11, 2013 | 07:40 AM
99 Blue lightning's Avatar
Default Need help/opinions on trans
I have a 4l60 stock tranny in my 99 ss...... Wondering on opinion/suggestions about input shaft upgrades or rebuild kits .... Any info is appreciated
Old Mar 12, 2013 | 09:42 AM
mrvedit's Avatar
Moderator
There are many threads on the question of rebuild kits. Here are two:
https://ls1tech.com/forums/automatic...-rite-kit.html
https://ls1tech.com/forums/automatic...-my-4l60e.html
IMHO (and I am no expert), the input shaft is one of the last things to worry about. However, performance builders often install the Sonnax Input Drum Reinforcement Kit (#77733-01K) which then also requires an old-style aluminum forward piston (Sonnax makes a billet one - #77764-01).
I've been told that the output shaft if more likely to break than the input shaft, which makes sense since the trans is multiplying the torque, especially in 1st gear. Billet output shafts ($500) and input shafts ($400) are available.
I would very highly recommend at least a updated Sunshell, 7 or 8 friction 3-4 clutch and the TransgoHD2 shift kit or at least a .490/.500 boost valve.
How much power are you planning on? Any adders?
I've been told that Nitrous is especially hard on a 4L60E.
