Vibrations in transmission while in park?
Old Mar 30, 2013 | 11:29 PM
lances's Avatar
Default Vibrations in transmission while in park?
Ok. so I recently picked up a 1999 camaro z28 auto trans. I'm trying to work some kinks out of the transmission.
1st. I have this vibration in the car the higher the RPM's the worse it gets I was thinking u-joints but not so sure because if I leave the car in park an rev it I get the same vibrations as if I'm driving it any ideas on what this could be?
I just wanna figure it out because it's annoying an well I'm sure it's not good for the transmission, also I plan on changing out the torque arm/trans. mount because I get this thud sound from under the center console an been told that it's more than likely that so I just wanna do all this at the same time.
Any help would be great full!!
Thanks Lance.
Old Mar 31, 2013 | 04:57 AM
umair's Avatar
Go to an oil change shop and get underneath the car with a flashlight and inspect (2)engine and (1)transmission mounts. If they are cracked, collapsed, or rubber missing the time to change them.
Old Mar 31, 2013 | 07:22 AM
senicalj4579's Avatar
Check your trans and engine mounts.
Old Mar 31, 2013 | 07:29 AM
LS79CAMARO's Avatar
I'm gonna hafta say check the motor/trans mounts also
