4l60E-HD2-C questions
My question is: The hd2-C instructions says gear command. Does this mean if I can manually up-**** the car from 1-2-3 and manually 3-2-1 if I want?
Or
Does it mean if I leave it in first it stays there, if I put it in 2nd if will start in first... go to 2nd and back to first? Same thing with third.
Or
Does it do both.
My converter is tight so I want to get spirited sometimes I'll come to a complete stop and go wot from 1-2 then get to speed and pop it up to drive. Just want to make sure I'm not doing any damage.
Normally the PCM completely control the shifting. The "gear command" valve forces the trans to be in a gear no higher than what you have selected. However, if the shifter is in e.g. [D3], the trans will not upshift into 3rd until the PCM tells it to according to its programmed speed. In other words, when you move the shifter to a higher gear, the trans will not necessarily shift then. However, if you move the shifter to a lower gear, the trans will immediately downshift.
Here is how Transgo explains it:
"Back shift to any gear at your command. Holds the gear you select to any rpm."
It is NOT the same as a full-manual valve body.
Most people here will concur in my opinion that there is no reason to manually upshift. Let the PCM do it. If you mod the engine, you should should not only tune the PCM for those mods, but perhaps also tune the trans shift points for best performance.
I run a high duration/lift cam and at WOT I program my trans to shift at 6900 RPM with a rev limit of 7000.
With this feature, you put it in first and it will not upshift until you do so. You can manage your traction situation much more effectively.
I would never downshift the car while rolling. At the track I have radials and wouldn't do this. Just for situations like above. Sometimes I'll drop if into the lower D while rolling. My converter is tight and unless I'm at the perfect mph it doesn't always rip.
Just wanted to know if those occasional 1-2-3's would hurt something.
