Tranny Cooler Questions/suggestions?
Do you have the cooler hooked up to the stock cooler or by itself?
Moving on to getting my first trans temp reading. While I was first setting it up, without downloading the intructions first like it says to do, I had the car idling for about 15 mins or so. Trans temp was at 187. I realized I was going to need to print out some intructions. Needed to figure out how to set scan time and warning lights. Also needed to know what DM meant. Which means Duramax, FYI. So, I went inside to print them and what do you know, no ******* ink in the printer. I decided to eat dinner and then went over to my sisters house. Which is exactly 1.9 miles. Temp when I started car was 162 and it jumped up to 185 when I pulled in her driveway. When I came back the temp read 157 when I left her house and about 177 when I pulled into garage at my place. This is with normal stop and go. I did not flash the stall to 3200 one time. I do believe that the cooler must be moved and soon. After I get off work tomorrow, the temp outside should be around 90. I will try and get a video of the temp with my phone on the way home. I am hoping it will not go over 200, but I am guessing there is doubt it will. Thinking about maybe getting second cooler.
im also running an aeroforce gauge and its a great tool.
