4L60E, no 2nd or fourth
I'm having a problem with my 4L60E that I just got done rebuilding. Me and my buddy rebuilt a couple years ago, but the pump rotor let go. This last rebuild, we rebuilt the pump and tore the whole thing down for inspection.
Now, I do not have second or fourth gear now. It will go from first to third in (D). However, it appears now that it will hit second gear the first time I take off in the car, but that is the only time it ever hits second gear. After that, it will go from first to third.
I asked on another forum for some pointers and I was told my 2-4 servo/band could be the culprit?
Thanks!
Rob
First, remove the servo and carefully check the seals, especially on the 2nd apply (inner) piston. If that looks OK, you should check that that servo pin isn't too loose (too much free travel). The following directions for the Sonnax servo kit explain this:
http://www.sonnax.com/system/instruc...911-03K-IN.pdf
IMO, you don't need a dial indicator on it - anywhere between 1/16" and 1/8" should be fine. If it is indeed too loose, you will need to buy an extra-long servo pin and grind it down, as described in those directions. (You don't need the expensive Sonnax servo.)
Also, to help with a worn servo bore and leaking stock seals, Sonnax makes an o-ring kit (#77701-04SK) to better seal the 2nd apply piston:
http://www.sonnax.com/system/announcement/77701-04K.pdf
Thanks for the advice! The servo will be the first thing I will check! I forgot to mention, my trans is not stock. The servo was upgraded with the first rebuild a few years back. Everything was working perfect until the 13 vane pump rotor broke in four pieces.
Perhaps a rotor fragment got into the servo and damaged something you didn't notice.
Have you ever checked line pressure with a gauge?
I have not checked line pressure with a gauge.
I finally got my laptop to work right and I got a code 84, 3-2 downshift feedback fault. I was leaning towards Solenoid A, since I only have 2 and 3rd gear.
If might just be the 3-2 downshift solenoid, but unless you really don't mind dropping the pan over and over again, replacing all three gives you a good chance it will fix the problem and you won't have other solenoid problems for a long time.
