what 4l60-e trans will work
Old Apr 22, 2013 | 11:45 PM
abigassbowtie's Avatar
Default what 4l60-e trans will work
I have a 63 nova with a 2004 5.3 and am looking for a trans that will plug in and work. i dont mind having to use the flex plate spacer or having to switch a few pins around in the plug but prefer to get one that will just bolt in and go! what years will work out of what vehicles?
Old Apr 23, 2013 | 08:15 AM
mrvedit's Avatar
Moderator
You want a '98 through '06 trans from a V8. The bell housing needs to have a bolt hole in the 12 O'Clock position - that indicates it has a 300mm input shaft as needed to be LS compatible. A '07 or '08 might work, but I would need a picture of the valve body to confirm it.
