Shift Kit or HPP3 or Both?
Old Apr 24, 2004 | 12:26 PM
skunk50's Avatar
Default Shift Kit or HPP3 or Both?
almost stock A4 with stock gears for a '98 convert, so probably 3.23s.
going to spray 80-100 hp dry so i'm trying to protect my A4.
HPP3 is cheap (used) and has the shift firmness feature as well as other things like fan and speedo calibration and i probably need it for the speed limiter too.
Trans-Go shiftkit would be my choice also.
would going with both help more?
Old Apr 24, 2004 | 12:50 PM
Colonel's Avatar
No question, shift kit. TCI would be my choice for simplicity's sake but the TransGo is just as good if installed correctly. I've had both.
The HPP3 doesn't increase WOT shift firmness which is what you're looking for.
Old Apr 24, 2004 | 01:46 PM
flyinZ's Avatar
Go for the shift kit...Either TCI or Trans Go
Uping' the line pressure will only hurt the trans..
