converter and tune
Old May 4, 2013 | 01:24 AM
25006.0's Avatar
Default converter and tune
I got 3800 circle d today,can i drive car after install before retune without messing up trans or converter?i've already added trans.cooler.99 camaro 2.73s
Old May 4, 2013 | 09:48 AM
25006.0's Avatar
Anyone know?
Old May 4, 2013 | 09:52 AM
Circle-D's Avatar
As long as it is still shifting ok and locking up, you can drive it. But if it is not locking up then a retune is needed asap or the trans will get hot fast.
Chris
Old May 4, 2013 | 02:17 PM
25006.0's Avatar
Thanks chris.
Old May 11, 2013 | 01:30 PM
25006.0's Avatar
The converter is in now,night and day difference.lock up is fine but need to adjust shift points a little.It's loose with 2.73s,but fun to drive.
Old May 11, 2013 | 05:10 PM
mjs1012's Avatar
Whats your gear code on the inside of your door? I thought camaros came with 3.23s??
Old May 11, 2013 | 09:56 PM
25006.0's Avatar
I don't remember which code tells gear ratio but i checked when i got car.i wish i had the 3.23s though.
Old May 12, 2013 | 07:07 AM
justin hover's Avatar
Gu2 is 2.73(door panel). I fking hate 2.73s.
A 3.42/3.73 with a 3800 is a great combo
Old May 12, 2013 | 12:36 PM
25006.0's Avatar
Yes 3.42s would be great.
