4l60E time for a rebuild?
It's usually 2nd gear that goes away before 4th gear when you lose the band, though, due to there being much greater force against the band in 2nd than in 4th. I routinely see failed bands that won't hold anymore in 2nd, but will still hang on in 4th. Part of it also has to do with the direction the reverse input drum is spinning when the band is called upon to stop it and hold it stationary. In 2nd gear, the drum is spinning opposite of engine rotation, and in 4th it is spinning with engine rotation. I've seen broken band anchors give some weird symptoms as well...
In either case, the bad news is that you, most likely, are looking at a transmission build at this point...
And, yes, both an aux cooler and a deep pan are highly recommended...especially with a 3200 rpm converter.
BTW, do you like that converter with the CC503 cam? Seems like a lot of converter for that camshaft...
In another 6-month old thread the OP had no 4th after a rebuild, and after checking the servo carefully, a replacement Valve Body fixed it. Unfortunately I never learned where the VB problem was.
Dynamic396: Thank for the info that the reverse drum is rotating in opposite directions in 2nd versus 4th. That is good to know and I see how a marginal band might hold in one direction but not the others. Very educational.
A common mistake in the valve body that would give a no 4th condition is to put the 3-4 relay valve in backwards. I've seen that done many times by the first-timer...
Thanks for the info. Learning a lot today.
As far as the converter I like it, I do not seem to have an issue with the CC503 already installed and even considered a re-stall to 3600. It has lock up so maybe that is why I find it tolerable while on the street. Thank you both for the advice and information.
Good luck. Keep us posted.
I definitely wouldn't go to 3600 with your converter with that 503 cam. In fact, I bet you'd pick up some performance by dropping down to around 2800 or so. At 224/230 on a 112, it's just not that large of a camshaft. I have used the 503 on a few occasions, and it makes decent low-mid range torque, so that's where you'll want your converter. At 3200 (and certainly at 3600), I think you're over the top of the cam. Just my $.02...
T/A diff cover? Do you mean a cast aluminum one with the adjustable bolts to hold the bearing covers more firmly? I have one, but also had my tubes welded tot he case, Moser axles, Eaton posi.
It has held up for 60+ track runs at 500hp on drag radials.
