A4 won't do 2-3 shift on WOT
Old Apr 27, 2004 | 11:03 AM
RedHardSupra's Avatar
Default A4 won't do 2-3 shift on WOT
My 99 formula's A4 developed a strange behavior. It will not do a 2-3 shift on WOT. It works fine at ~85% throttle, but then it also shifts early(<5500rpm), so it's less than optimal. I put a trans cooler on, but it didn't change the behavior at all.
Any suggestions?
Old Apr 27, 2004 | 12:04 PM
94form2000z's Avatar
Needs to be edited to shift sooner or at lower RPM
Old Apr 27, 2004 | 12:46 PM
2001 Pewter WS6's Avatar
Restricted User
Sounds like the 3-4 clutch pack went bye - bye... It just happened to me as well. Smell your fluid...
Old Apr 27, 2004 | 01:06 PM
Kenafin_02TA's Avatar
If it's a fairly stock car, ie no torque convertor, stock gears, etc...I'd say something is about to go..or is gone in the tranny. Don't worry..I've been there twice already with blown trannies. Check the fluid...my fluid looks ok, but smells nice and burnt. For me it just confirms what I already knew, this tranny is on it's way out. But it's been on it's way out since the fall...since I need to drive the car everyday I try not to beat on her too hard..and the tranny has managed to last. (Yes I hate not being able to race...but that will be fixed soon). Get a good built tranny with a deep pan, and you won't have to worry as much. You said you already put on a tranny cooler so you're good there.
Old Apr 27, 2004 | 08:40 PM
It is a fairly stock car, stock converter, stock 3.23s, new diff. grrr, i didn't wanna do a new trans yet, i wanted to spend this year with A4, then next year convert to M6
what can i do to check beyond smelling the fuild? would shiftkit or nice servos help it any?
Old Apr 27, 2004 | 09:14 PM
Wesley SS's Avatar
nope nothin because the actual clutches are burnt or in my case actually cracked in half. If you dont want to spend a lot just get the clutch packs and install them yourself it isnt actually that hard to install.
