700r4 question
Old Jul 3, 2013 | 11:43 PM
Big bird55's Avatar
Default 700r4 question
I bought the b and m lock up kit for my 700r4 and when I went to remove the spring in the vavle body like the instructions said to I found I didn't have the spring the instruction says to remove. I circled in red what I pulled out of the vavle body and now I do not know if I am missing parts or not. What is circled was the only thing that came out. If it is all ok what do I do instead since I do not have the spring? do i just go out about wiring it up like the instructions says. Never messed with a 700r4 so this is confusing the hell out of me
Old Jul 3, 2013 | 11:48 PM
zgp's Avatar
zgp
your good, it is not needed.
Old Jul 4, 2013 | 01:26 AM
Big bird55's Avatar
ok thanks but am i missing parts? Or are they just showing 2 different setups
Old Jul 4, 2013 | 11:41 AM
pricesgarage's Avatar
1982-86 uses that spring 87 up uses the top sleeve
Old Jul 4, 2013 | 11:44 AM
is that the 4th gear switch kit or the hyd lock up were it doesnt require any ecm ?
Old Jul 4, 2013 | 01:54 PM
Big bird55's Avatar
the kit i bought is just a b and m kit that use vehicle speed of the speedo cable to tell the converter to lock up. can swap the parts to an 82-86 and it work or will it work like it is now?
Old Jul 6, 2013 | 10:13 AM
yes because the lock up is controlled by voltage the speedo switch just completes the circuit you should not have to do any vb mods
