converter not locking up????
Old Jul 17, 2013 | 01:04 AM
02 Camaro's Avatar
Default converter not locking up????
Hey all i have a FLT level 5 with a 4500 fuddle billet lockup stall and it must not like me bc it doesnt lockup.. I was cruisin the other day and it lockup for like 10 seconds and stopped so idk whats goin on If anyone know wth is goin on let me know asap any help is greatly appreciated
Old Jul 17, 2013 | 03:48 AM
nj02z's Avatar
I had trouble like that and it ended up being my misfire tables.I upped my tables and now it locks solid.Not sure it that is your troubles.Bigger stall converter and bigger cam triggers this.
Old Jul 17, 2013 | 05:30 AM
justin hover's Avatar
Check fluid again
Is torque managment removed?
Some times a touchy brake switch unlocks it as well
Old Jul 17, 2013 | 09:39 AM
mrvedit's Avatar
Moderator
Scan the engine for codes; not all codes turn on the MIL light. Any misfire or slippage codes with prevent converter lockup. Was the car tuned for a high stall converter? If not, that needs to be done.
And yes, a touchy brake light will cause this too.
Old Jul 17, 2013 | 11:00 AM
02 Camaro's Avatar
what do you guys mean by a touchy brake light?
Old Jul 17, 2013 | 03:31 PM
mrvedit's Avatar
Moderator
We had one case where the brake light switch on the brake pedal was adjusted so tightly that bumps in the road would trigger it - both flashing the brake light and disengaging the converter lockup.
Sure rare, but just trying to cover all possibilities.
In the vast majority of cases, the PCM was not tuned, or not tuned correctly for a high stall converter.
