Tuning for Sy3500
Anyhow I opted to go for tuning when I did my converter install, but the main reason was because I already had headers on the car. Also wanted to do some shift points, TM, and whatever else is need for a converter install. Also might want to take care of P0757 while your at it, it gets annoying....I have to go back to the shop one of these days and get that code taken care of
I would save the tuning dollars for the heads and cam, or order LS1-Edit latter on and do the TM delete yourself and have them use your copy for tuning when you get ready to tune.
Give yourself 2-4 days to adjust your ears and foot to the new combo and that's all the tuning you'll need. Then go Nitto shopping.
Rick
I had mine custom tuned only because i have a guy that will do mine for the life of my car.
gears,Vert's,Cam's.. guess i'm lucky like that.
Anyway, prior to the tune my car did throw the "slip" code.
Man you will love that converter!!! & yes you will need some nitto's.
I put new Kumho's all the way around prior to the vert install & the rears are smokn!!!
Good luck.. Good choice!
