Install shift kit with new stall?
Old Jul 31, 2013 | 01:18 PM
Kwikasfaki's Avatar
Default Install shift kit with new stall?
I have a 2000 camaro with 114k miles. There were two owners before me but they took real good care of the car and kept every receipt of things replaced or work done to it. When I got it it was completely stock and I added the ls6 intake, headers, true duals, and 3.42 gears. I already ordered a yank ss3600 and tranny cooler. I plan on sending my computer to frost to get tuned and wanted to know if I should install a shift kit since I read that with the stall the shifts will feel softer and slower or will the tune be enough. I've been trying searching for days and still cannot find exactly the answer I'm looking for. If anyone has some experiences with this please chime in I'd appreciate the responses.
Old Jul 31, 2013 | 03:26 PM
sjsingle1's Avatar
trans go or sonnax........i recommend the sonnax
leave the trans out of the tune IMO
Old Jul 31, 2013 | 08:58 PM
Kwikasfaki's Avatar
The kit I've been looking at is the transgo hd2. Is there a reason to leave the tranny out of the tune?
Old Jul 31, 2013 | 09:02 PM
mrvedit's Avatar
Moderator
Installing the Transgo HD2 or Sonnax Performance Pack shift kits involves removing the valve body and some disassembly of it. It might be intimidating if you have never worked on a trans before.
I would suggest starting with just the Sonnax 4l60E-LB1 boost valve ($25) which is trivial to install and will by itself give you many benefits of a shift kit, including tighter shifts; plus higher line pressure to reduce slippage and wear.
If you think you will likely install a full shift kit in the future, you could buy either the Transgo HD2 ($80) or Sonnax Performance Pack ($125) and install just the boost valve from the kit for now. The Sonnax kit is more comprehensive and replaces parts which have likely worn. (I personally run a combination of both kits and more.)
Old Jul 31, 2013 | 09:14 PM
Z28SLPCAMAROZ28's Avatar
Not to thread hi-jack, but I figure it will probably be asked anyways, what mixture of parts do you have?
Also, yes, I have searched and found your threads where you talk about your different parts. But I know little about transmissions... Do you have just a list of it?
Thanks and once again sorry, I don't mean to thread hi-jack...
Old Jul 31, 2013 | 10:18 PM
RevGTO's Avatar
Pontiacerator
Definitely recommend the Transgo HD-2. I talked at length with Dana at Probuilt Automatics and bought the kit from him. Since I know little about transmission internals, I found an experienced guy to do it. Well worth it. The right time is when the tranny's out of the car ...
Your new converter is much smaller than the stocker and thus moves less fluid. This has to be compensated for. Plus there are advantages to converter clutch life and of course, firmer shifts. I've driven stalled cars without a kit and didn't like the shift quality.
Search for some of mrvedit's write-ups on the Sonnax pieces. Lots of good info.
