T56 to 4l80e newbie help!
Old Aug 2, 2013 | 09:02 AM
GW54's Avatar
Default T56 to 4l80e newbie help!
I bought a 99 trans am that somebody swapped the stock auto for a t56. But didn't change any wiring. I was told that's the reason my reverse is destroyed. Anyways I would really like to switch to a built 4l80e. Should the stock wiring just plug in? Or is there something else I need to do
Old Aug 4, 2013 | 08:53 AM
cabel1's Avatar
On a 99 you will need a segment swap done to make it shift correctly
Old Aug 4, 2013 | 08:07 PM
YURVIEW's Avatar
And a wiring adaptor kit. Sold by Speartec and pcmforless. The "segment swap" mentioned by cable1, refers to the pcm tuning. You will need to download a portion of a truck tune to allow the fbody pcm to control the shifting f the 4L80e.
