po753 and po758....
Old Aug 13, 2013 | 08:41 PM
CarolinaTA's Avatar
Default po753 and po758....
Car has a 4l80e in it with a 4000 yank stall, is throwing po753 and 758 for shift solenoids a and b, i know this means it has no power or no ground but dunno where to start, anyone else had this problem before?
Old Aug 14, 2013 | 06:10 PM
CarolinaTA's Avatar
Found a service bulletin about if both codes are present and you don't have proper voltage at the transmission, i had half a volt at the power wire, then replace the igniton switch, think im gonna try that.
