4l80e TCC won't unlock. Ideas?
Hey guys,
I am trying to finish up a 370ci/4l80e swap in my dad's 87 Monte SS and I cant figure out why the TCC will not unlock when I come to a stop.
When I first start the car, it will go in reverse and drive and idle just fine but after I drive the car and the TCC locks up and then I come to a stoplight, it pushes on the brakes hard and most of the time it stalls unless I pop it up in neutral. With that said, if I leave it in park for a minute or two, it will go back to idling in gear like it is supposed to like the pressure leaks off or something
I found this thread: https://ls1tech.com/forums/automatic...put-drive.html
After reading that, I decided it would be a good idea to cut the TCC ground wire so I did. Negative results.
Also to back up for a minute, the brake switch is connected for the TCC. Anyone have any other ideas? Trans has HD2 kit installed with stock converter and TSP 228r cam in the motor.
Derek
Derek
found a fix for now. i disabled shift lock in the auto TCC tab on HPTuners. the 228r cam still pushes pretty good on the brakes with stock torque converter but its not shutting off at a stop light.
thought i would update this thread for the next person with this problem.
derek
derek
